FTTP BT Speedtest - test 3 help required
- Full Fibre
- FTTP BT Speedtest - test 3 help required
15-10-2010 10:02 AM
Hi guys,
Is anyone on FTTP available today to run a couple of tests please? We're investigating a speed fault with one of our customers and I need to run test 3 on the BT speedtest. Problem is, it isn't working so I need someone else to run it on an FTTP line to see if it's a general issue or not. In order to run it though you need to get a speed low enough. So what I need to do is simulate a slow speed (I can do that on our side).
If anyone's available today can you let me know please and I'll give you a call and we can run through the test (please don't run the test before as you can only run one in a certain time frame).
Thanks,
Thanks,
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 1 of 3
(1,529 Views)
2 REPLIES 2
Re: FTTP BT Speedtest - test 3 help required
18-10-2010 9:04 AM
Stilll looking for help?
If so call me.
Happydays
Kevin.
If so call me.
Happydays
Kevin.
Message 2 of 3
(509 Views)
18-10-2010 4:21 PM
Thanks Kevin, BT have made a change so I'm hopeful it works now. If not I'll be in touch. Cheers.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 3 of 3
(509 Views)
- Full Fibre
