FTTP BT Openreach fibre modem blew up! Replacement?
YellaFella
I’ve turned this on today and smelt something burning and realised either the adapter or the modem is dead. How do I go about getting a replacement for this? I’m not sure what type of modem I need for this. Cheers.
Tags (3)
10 REPLIES 10
Fixes: 1,550
Re: FTTP BT Openreach fibre modem blew up! Replacement?
Sorry to see this, that’s not good at all. We’ll need to arrange an engineer to replace this, could you report a fault to us at http://faults.plus.net and post back once you’ve done so?
We’ll then pick this back up as soon as we can and arrange an engineer with you.
YellaFella
The service is temporarily unavailable when going to the link.
YellaFella
Hang on a second there’s no issue with the broadband line as such it’s the FTTP modem requiring the ONT fibre cable that’s broke.
Fixes: 1,550
I’m afraid we don’t stock Openreach modems to order these ourselves so we’ll need to arrange an engineer to replace this.
I’m not actually in the office this weekend, if we don’t pick this up sooner we’ll arrange an engineer with you on Monday.
Apologies for the inconvenience caused.
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to FTTP Trial board.
YellaFella
Not at all. Monday is fine with me. Have a good weekend.
Aspiring Hero
Fixes: 33
@YellaFella
Sorry, I'm confused here.
Is it the ONT box on the wall that's gone kaput or is it the router that plugs into the ONT (with an Ethernet cable).
If it's the router, then any VDSL router will work (if you happen to have a spare).
Fixes: 1,550
Thanks for getting back to me @YellaFella
Just to clarify, is the ONT box itself broken or are you referring to the router as Brian’s indicated?
YellaFella
This is actually the power adapter plug that seems to have blown not the ONT modem itself.
Fixes: 1,550
Thanks for clarifying @YellaFella
It looks like you're back up and running as of last night, did you manage to buy your own power adapter?
