FTTC trial and old socket
- Full Fibre
- FTTC trial and old socket
25-08-2010 11:38 AM
Hello
I planning to apply for the FTTC trial when my exchange is enabled (end Sept).
I have a 22 year old BT socket at present which is accessible for inserting/removing plugs is otherwise inaccessible. Does this matter, or should I plan to make it full accessible for replacement?
Dave
Dave
Message 1 of 2
(1,790 Views)
1 REPLY 1
Re: FTTC trial and old socket
25-08-2010 1:17 PM
Hi Dave,
The engineer will need to get to the master socket to install FTTC, or at the very least get to the point where the line enters your property. They can replace the socket when they do the faceplate if it's an old socket although where it's located, or where they run the extension cable to will need a power socket nearby for the modem and the router.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 2
(488 Views)
