FTTC to FTTP router upgrade
Eggs
Re: FTTC to FTTP router upgrade
The engineer has left the copper land line and I can still use my landline telephone.
The engineer said it was a good idea to keep in in case of issues over Christmas.
willcutforth
Fixes: 113
That makes sense just for now at least
 Will Cutforth
Eggs
I know it is still early days but I really am over the moon with the service and speed.
I should have done it months ago but I have always had a tendency towards the "if it ain't broke" attitude.
willcutforth
Fixes: 113
I have this tedency to just put things off for the same reason haha. I'm so glad you're happy with the speed. I can't get Full Fibre at the minute so I'm not jealous.. Much haha
 Will Cutforth
markhawkin
All Star
Fixes: 20
For completeness, TP-Link say the TL-WDR3600
"Achieves blazing WAN to LAN throughput of over 800Mbps with hardware NAT"
https://www.tp-link.com/uk/home-networking/wifi-router/tl-wdr3600/
so actually well up to most FTTP services.
It seems to be excellent value second hand as well.
I've generally been pleased with TP-Link stuff.
Eggs
I would certainly have taken advice before buying this router, and it was advice well given. I haven't had a peep out of it since I bought it. It was to replace a router I had been given as part of a package, but I am not sure if it was when I switched to Plusnet  or my previous supplier - Be. Be was bought by Sky and the customers were migrated to the Sky network with the predictably terrible results. It was really bad. It is the only time I have ever had the misfortune to be a customer of that company.
Eggs
I am in the process of having a PC spring clean by renewing passwords, deleting unused stuff and organising the rest.
I have been sniffing about in the router and can see my connection details as my plusnet email address (which I have never used) and a password. I cannot see this password and I don't think I can remember what it is.
Anyone have any ideas?
RealAleMadrid
Fixes: 66
@Eggs Your Plusnet username is in the format username@pludsl.net it is not your email address, the username and password are the same as that used to login into your member centre Plusnet account.
Eggs
I see. And since I have just changed that password I assume I will need to chnage it in the router when it reboots?
Fixes: 532
You will
ad47uk
We now have access to openreach fibre, and like you, I have this if it works then why change and to be honest 36Mb/s is fine for me. I realise at some point I will have no choice but to change, but at this moment in time I don't see any advantage for me.  I have a old TP link Wr1043Nd router, which I am thinking of putting back in line as my old Hub 2 is playing up. I know the TP link is very old, but even on the lower end FTTP services, it should work fine.
