FTTC check
- Full Fibre
- FTTC check
FTTC check
02-03-2011 1:18 PM
Hello
I have followed the sticky above about checking if WBC FTTC is enabled for my address. The exchange certainly is but the cabinet check is confusing. It says..
Your cabinet is planned to have WBC FTTC by 31st December 2012. Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 32.5Mbps and upstream line speed of 7.2Mbps.
So do I have to wait until December 2012 or am I good to go now?
Ta
Rabid
Ta
Rabid
Message 1 of 2
(1,312 Views)
1 REPLY 1
Re: FTTC check
02-03-2011 1:50 PM
If it shows a date you are not enabled. Did you look by postcode or phone number?
Note: the date given in a holding date when BT don't have a clue when it will be enabled.
and yes, it is a confusing message.
I think you meant to post in an existing topic but must have created a new topic instead.
Message 2 of 2
(334 Views)
