FTTC and Vigor 2710
rockyhorror
FTTC and Vigor 2710
Just wondering if anyone has managed to get a Draytek Vigor 2710 to work with FTTC?
Setting LAN4 as PPPoE (with the usual logon info) will not work. Incidentally, on the PPPoE/PPPoA menu I can only select 'Channel 1' from the 'Multi-PVC' drop down menu.
BTW, big thanks to PN for allowing me on this trial - it works great with the supplied kit.
Thanks,
Richard
1 REPLY 1
adamwalker
Fixes: 216
Re: FTTC and Vigor 2710
It's build for ADSL rather than fibre so the lack of a WAN port might scupper you there. However I'd be keen to know if anyone has tried this.
 Adam Walker
