[FTTC] Trial feedback
- Full Fibre
- [FTTC] Trial feedback
25-10-2010 7:05 PM
Install painless and quick, Engineer helpful and informative.
(definitely work pre-configuring router as per instructions)
Speed difference astonishing.
Was lucky to get 2mbps download in past now have a rock solid 35mbps (upload is an equally amazing 8mbps)
Note this is despite being a good 400 metres, as the crow flies, from the cabinet.
Re: [FTTC] Trial feedback
26-10-2010 1:01 PM
Plusnet Technology
26-10-2010 8:52 PM
A marked performance drop today from the heady heights of day one 35 mbps to 23 mbps
Still an improvement on the downstream line speed of 14.5Mbps and upstream line speed of 5Mbps that the BT wholesale broadband checker was predicting
'my broadband speed' results
Today 20:39 23315 kbps (2.91MB/s) 5947 kbps (743kB/s)
Today 08:03 35331 kbps (4.42MB/s) 8250 kbps (1.03MB/s)
puzzled by the drop as I doubt it's contention. BT engineer said I was only the 18th customer using the new FTTC cabinet
(yes I'm testing using a wired network connection to ensure there are no wireless performance issues impacting the results)
26-10-2010 9:04 PM
i really miss having the stats from the modem on line noise etc so you can tell what is actually going on
i find that although i get a high maximum i still get wild variations on speed, sometimes dropping below 1mbits
much worse than on adsl2+
not really had any convincing explanations as to why this happens, but it makes it almost unusable at times
will be interesting to hear what you find as sounds like a similar line length to me
26-10-2010 10:23 PM
27-10-2010 8:37 PM
download speed still hovering around 24 mbps with upload speed of around 6mbps
Puzzled by drop from 1st day's amazing figures.
Does anybody know why would that happen ?
28-10-2010 12:42 AM
Quote from: tomorrowman Does anybody know why would that happen ?
i think it's training at least thats what i've been told
so implies there have been connection drops etc
like i said above wish we could se what is actually going on in the modem so we could verify for ourselves
28-10-2010 9:22 AM
28-10-2010 10:01 AM
Sync Status In Sync
Downstream Speed 24.421001 Mbps
Upstream Speed 7.2000003 Mbps
Looking at your connection logs there where a few drops on the first day so it looks like the systems decided the line was a bit unstable and decreased the sync speed, since then it's been stable for over 2 days. It may change if you reboot the BT modem.
Plusnet Technology
29-10-2010 8:29 AM
Tried the modem reboot suggestion. Can't say it made a significant difference:
Date Download Speed Upload Speed
Today 08:08 23400 kbps (2.93MB/s) 5967 kbps (746kB/s)
Would I be correct in thinking the 'determining of the sync speed' is similar to ADSL i.e.
for the first x days limits set high while 'the system' finds it's optimum speed/quality level.
If so take it the ISPs have a function to 'redetermine sync speed'
P.S. Impressed so far
29-10-2010 8:45 AM
pre FTTC wireless router, home server etc where all upstairs off the extension phone socket.
as part of VDSL upgrade decided to relocate all of this to be close to master socket (did not fancy having x metres of cat5 cable draped around house).
So all kit is now under couch.
Decided not to continue using the supplied netgear WNR1000 router and reverted to using my Linksys WRT610N dual band router.
Found wireless signal strength was a little better with Linksys + use 5Ghz N band for good for HD media streaming (less congestion with neighbours broadband)
One minor niggle - PS3 previously had wired connection to router, now wireless. However PS3 wireless is only G, so download speed is actually slower than broadband connection.
(better start looking for a N wireless bridge/access point for the PS3 then)
If you do use wireless connections you really do need 'N' to take advantage of the speed offered by this FTTC broadband.
29-10-2010 11:43 AM
We found the same with wireless G/N. When we first did the trial we capped the speed at 20Mbps and G could just about cope with that OK. When we removed that limit you could see the difference straight away. We then tested a whole load of different routers out and started using the WNR1000.
Plusnet Technology
31-10-2010 10:26 PM
Unexpected but welcome speed increase.
Today 22:14 28585 kbps (3.57MB/s) 8238 kbps (1.03MB/s)
Yesterday 14:23 24199 kbps (3.02MB/s) 5962 kbps (745kB/s)
03-11-2010 6:38 AM
Getting a solid 31000 kbps +/- 500 kbps download speed for the last 3 days
upload remains in the 8225 - 8250 kbps range.
03-11-2010 2:44 PM
Plusnet Technology
