FTTC Trial Fibre run question
- Full Fibre
- FTTC Trial Fibre run question
22-02-2011 2:40 PM
I am intrigued, as I am able to join this trial, about how the fibre is run to the house.
I live at the end of a private drive way, will this need to be dug up?
Message 1 of 5
(1,241 Views)
4 REPLIES 4
Re: FTTC Trial Fibre run question
22-02-2011 2:46 PM
FTTC = Fibre to the Cabinet. So fibre is only run to the cabinet. From the cabinet the existing copper wire are used.
Message 2 of 5
(456 Views)
22-02-2011 2:49 PM
ah ok... the sales rep linked me to:
http://community.plus.net/blog/2010/07/20/100mbps-has-arrived-plusnet-begins-fibre-to-the-premises-t...
which shows it going to the house????
Message 3 of 5
(456 Views)
22-02-2011 3:09 PM
FTTP is to the premises/house and will use the existing method from cabinet to house, subject to survey. So does the existing use telegraph poles?
Message 4 of 5
(456 Views)
22-02-2011 4:42 PM
its ok, the rep tell em I can have FTTC but links me to FTTP info!
Thanks for replying much appreciated...
Message 5 of 5
(456 Views)
- Full Fibre
