FTTC Questionnaire Email
- Full Fibre
- Re: FTTC Questionnaire Email
22-02-2011 4:17 PM
I'm sending out a questionnaire this afternoon to all our FTTC customers, I know some of you won't have been on very long while others have been on over 18 months now. If you can take some time to fill it in when you receive it that would be very much appreciated. We're currently running through the commercials and all the other details for our FTTC product so any feedback you guys can provide now will help us shape our fibre products. Thanks in advance.
Plusnet Technology
22-02-2011 5:42 PM
Do you want any routers back?
I have a Netgear, Thomson & Zyxel from you and only the Netgear is in use.
23-02-2011 8:29 AM
Since getting FTTC (BTopenreach modem permitting) I've been getting a steady 30-32Mb (after the initial settling in period) day or night.
So do I answer 😧 I have experienced no difference in speed.
Because in real terms that isn't true going from ADSL to FTTC!
23-02-2011 9:04 AM
@dave - I haven't received the questionnaire. Are you sending these out in batches?
James
23-02-2011 11:08 AM
Kevin - thanks yeah I can see that none of the answers really applies there, I'd suggest putting answer A I no longer suffer with slow speed if you've not already completed it.
James - the survey's been sent but looks like we don't have an email address on your account. If you log in to the member centre and go to account details then update details you can add an address and if you go to the help and support section there's a ticket on your account with a copy of the email and link to the survey.
Plusnet Technology
23-02-2011 2:06 PM
Thanks Dave. I have completed the survey.
James
24-02-2011 5:08 AM
Also just to add, since switching to FTTC I have never been happier to be a PlusNet Customer. Thanks again Dave.
24-02-2011 11:05 AM
But since we're on the subject of routers - If I wanted to get an upgrade, what type am I looking for (a cable router?) and is there any movement on being able to use a combined modem and router yet?
24-02-2011 11:15 AM
If you read though the relevant BT SIN 498 - Here you will see that monitoring and management is tightly tied into their [BT] modem
It would be good if BT could make the stats information readily available to Plusnet who could then add it into their portal...hint...hint
24-02-2011 1:14 PM
12-03-2011 7:05 PM
Hi, I just read about questionnaire are you still doing them? Seems account details was missing my email address as well, I've added it.
Alan
(User apogee)
- Full Fibre
