FTTC - Pro account
JasonE
FTTC - Pro account
Now that FTTC is up and running at gorgeous speeds I did some homework to find out why Iplayer , PSN , peer-2peer etc etc etc aren't getting the full bandwidth and discovered that because Im on a Value package all these services are capped at various levels... you get what you pay for I guess.
My question is:  Is there still a Pro package availible to take advantage of the new speeds as I seem to remember that all the services where max'd ( line speed) out that.  ?
5 REPLIES 5
jelv
Fixes: 10
Re: FTTC - Pro account
http://www.plus.net/residential/broadband/pro.shtml
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
JasonE
ahhh , I see it now...  bit hidden isn't it?  Shocked
20Mb usage is a bit mean isn't it ?  Sad  Can you confirm that ALL services are un-capped and 'linespeed'  ?
Thanks.
Be3G
I think you mean 20GB – 20Mb over FTTC would take just over half a second to download. Grin I can indeed confirm though that there are absolutely no restrictions to the speed of any protocols on Pro, although the product is still susceptible to traffic management in unusual cases (such as a significant portion of Plusnet's capacity going offline).
JasonE
Embarrassed  yes , 20GB your quite right. sorry.
I'm guessing I could always add extra usege to the Pro product  Roll_eyes
Thanks.
matt_2k34
indeed, but at £5 per 5GB, its not a cheap way of getting very fast speeds...
Smiley
