FTTC New Install
- Full Fibre
- FTTC New Install
FTTC New Install
24-01-2011 7:39 PM
The speed increase was immediate! This afternoon I was getting 36M down / 8M up, which has now dropped to 24M down / 8M up (is this due to the busier network in the evenings?)
The improvement on my ADSL (which ran typically at about 2.5Mb/s) is superb, especially for downloads and high bandwidth applications like Google Earth.
I did find the signal strength and stability of the wireless on the supplied router (Netgear WNR1000) wasn't quite as good as with my old router (Linksys WAG160N), so I have switched the wireless off in the Netgear and am using the Linksys as a wireless access point. With this arrangement I am getting full speed on laptops connected via wireless.
I must say the whole ordering / installation process has gone very smoothly - many thanks to the Plusnet staff involved.
Mike
Re: FTTC New Install
24-01-2011 7:56 PM
Getting 37197kbps down and 8346kbps up. Installation was smooth, no probs at all. Really happy with how it's all going so far.
Thanks Plusnet!
24-01-2011 8:23 PM
Although I have been dealing with business deployments on the trial, the majority have gone very smoothly. The remainder are down to changed requirements for the most part.
25-01-2011 7:49 AM
All went very smoothly. As soon as my router made connection, I had a speed of 32.8 and 8.29.This morning it's showing even better at 39.12 and 8.33
The Netgear router only arrived in the post during the afternoon, but I'd already configured my current router (NETGEAR Prosafe DGFV338) and it plugged in and worked without a hitch.
As far as I know the Prosafe router has a more sophisticated FIrewall so I intend to continue to use that (as long as that's okay with Plusnet).
I do intend to try out the new router to assess the 'n' wireless.
25-01-2011 4:53 PM
My FTTC connection was commissioned without any real problems on Jan 20th.
The miserable 1.8Mb/s down load performance I was getting and had "moaned" about to Plusnet is now at a so far consistent 21Mb/s, which is a rate that I "could get used to" .
I think the PlusNet end was caught early in the day and un-aware because the first 15 mins were spent examining the integrity of my 20m cat 5 feeder from the BT modem to the Plusnet Netgear router, because no change from the 1.8Mb/s snail like performance could be detected, then suddenly it took off.
On a lighter note: my wife, an Archers addict is very pleased as her weekly Omnibus is now transformed to a fast MP3 download. So she doesn't have to remember to set the PVR.
Thanks for having me in on the trial . .
Rick C
25-01-2011 7:54 PM
26-01-2011 11:37 AM
26-01-2011 3:30 PM
Average closure time: 1 day, 2 hours, 59 minutes and 38 seconds
Target closure time: 4 hours
Only 23 hours off target
28-01-2011 6:52 PM
I remember the days when you *did* get a four hour response time.
Completely powered down the BT box for a while. Connection speed back to normal. I shall close the tickets now. Wonder how long it would have taken?
28-01-2011 11:24 PM
An agent just needs to change your speed profile. I'll see if I can grab the attention of one tonight
Ex-Broadband Service Manager
28-01-2011 11:40 PM
Your profile is set right now. It ~was~ downgraded by a delta update, but it's been put back afterwards.
31-01-2011 8:48 PM
All working fantastically again.
