FTTC Fault 36245505 - Router Trials
- Full Fibre
- FTTC Fault 36245505 - Router Trials
26-10-2010 12:51 PM
Hi BT are working on my FTTC fault.
They want me to test the line without a router to rule out a router issue which I can do. But are BT aware that we are all not using the standard Thomson?
Also it mentions on my ticket that a bridge case is open currently in association with this fault. Do you know what that means?
Finally it refers to the fault going into AA - any ideas what that is?
thanks
thanks
Message 1 of 2
(1,034 Views)
1 REPLY 1
Re: FTTC Fault 36245505 - Router Trials
26-10-2010 12:57 PM
From the BT point of view I don't think they know what routers people use (and it shouldn't really matter). We've got at least 20 or 30 odd different routers in use by our customers.
I think the bridge case is because they've had some problems running some of the diagnostic tests, I wouldn't worry about that.
AA means awaiting appointment so once you've tested with the PC they'll want to book an engineer I think.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 2
(328 Views)
- Full Fibre
