FTTC 80/20 Trial- Still Capped at 40MB
- Full Fibre
- FTTC 80/20 Trial- Still Capped at 40MB
27-07-2012 2:53 PM
Recently I've been upgraded to the trial.
My upload speeds have shot from 1.8MB to 16MB-20MB.
However my download remains rooted where it was before at 37MB maximum.
Is there anyone here who could assist or has similar experiences ?
Message 1 of 6
(2,153 Views)
5 REPLIES 5
Re: FTTC 80/20 Trial- Still Capped at 40MB
31-07-2012 4:26 PM
Hi there and sorry for the late reply.
I've checked and can't see anything obvious that might have caused this problem. I can see you've raised a fault with us which is the right thing to do. Someone should reply to that ASAP.
Message 2 of 6
(628 Views)
03-08-2012 11:37 AM
Haven't had a reply yet.
It's a little perplexing, since rebooting the router my DL speeds have increased to 52MB, on speedtest.net.
But I'm literally around less than 200m from my roadside cabinet and the line is copper not aluminum (A BT engineer confirmed this)
Judging from VDSL2 line length signal degradation graphs I should be getting around 60+.
Just wonder if you have any other things I can try to do.
Message 3 of 6
(628 Views)
03-08-2012 11:51 AM
I've just checked and the fault was automatically closed as the checker wasn't completed within 48 hours. So I'd go back and do that again if it's still an issue.
Make sure you've tested the speeds having connected by Ethernet if you otherwise connect to the router through wifi. Also if you have access to an alternate router it's a good idea to try that too.
Adam.
Quote just wonder if you have any other things I can try to do.
Adam.
Message 4 of 6
(628 Views)
03-08-2012 5:53 PM
Quote from: markg140 Haven't had a reply yet.
i'm about 200m from mine and only getting 46mb. bt profile says max of 54mb which makes me wonder what the bloke who lives outside the cabinet could get if he was connected. I can practically see him in his living room if i look hard enough!
do you know what your attenuation is on the line?
Message 5 of 6
(628 Views)
23-08-2012 5:01 PM
I don't know how to pull line stats from the modem.
I'm syncing at 58Mb at the BRAS not sure why I'm not seeing them speeds though,
Message 6 of 6
(628 Views)
- Full Fibre
