FTTC 80/20 Has Trial Ended
- Full Fibre
- FTTC 80/20 Has Trial Ended
18-07-2012 7:15 AM
Has the 80/20 Trial ended.
The reason I ask is I'm getting rather tired of phoning up to get my profile reset.
Checking https://portal.plus.net/my.html?action=stable_rate I find yet again my profile has been reset to 40Mb (last phone call to get reset was a few days ago, Within a couple of hours I was back to 72000kbps, although I doubt that lasted for more than a day).
Support are helpfull but why does it keep getting reset?
I can only assume the trial has finish.
Message 1 of 3
(1,282 Views)
2 REPLIES 2
Re: FTTC 80/20 Has Trial Ended
18-07-2012 7:28 AM
No the trial has not ended.
You need to have a bit of a read of this forum. It's a well known ongoing issue to which many are suffering.
Have a read of this thread - http://community.plus.net/forum/index.php/topic,102776.0.html the last several pages are people with the same issue.
Paul
Paul
Message 2 of 3
(433 Views)
18-07-2012 7:31 AM
This reply by Chris is particularly relevant: http://community.plus.net/forum/index.php/topic,102776.msg907133.html#msg907133
Quote from: Chris Can we ask that if you're having this problem you post in here rather than raising a fault or contacting the support team, this is a trial and one of the terms of the trial was that support was via the forum! Thanks.
Call me 'w23'
Message 3 of 3
(433 Views)
