FTTC - 15 NBG-417N Routers for testing
- Full Fibre
- FTTC - 15 NBG-417N Routers for testing
21-12-2010 11:43 AM
Zyxel have kindly sent us some NBG-417N routers for testing, if you'd like to give one a trial please reply back and I'll get the sent out (chances are they won't arrive before Christmas).
Plusnet Technology
Re: FTTC - 15 NBG-417N Routers for testing
21-12-2010 11:49 AM
I'll give one of the Zyxel routers a go...
Cheers,
James
21-12-2010 12:12 PM
yep i'll give one of them a go too.
will be interesting to compare them to the netgears.
cheers
pete
21-12-2010 12:41 PM
I'm currently using a Zyxel NBG334W which for some reason is being fairly unreliable (occasionally just re-boots) so wouldn't mind trying one.
FYI I'm using it in "bridge" mode to "expose" my public IPs on the LAN side, then use extra firewall/NAT for PCs etc.
Richard
21-12-2010 8:15 PM
umm do you need my plusnet username ?
Regards
Ian
21-12-2010 9:22 PM
I would like to try one please.
Dave
22-12-2010 10:15 AM
Plusnet Technology
22-12-2010 11:34 AM
I'll give one a go; having all sorts of problems with the Belkin card in my work laptop connecting to the Netgear at the moment.
Thanks,
James Mayl
22-12-2010 1:55 PM
Cheers
Old Coggers
22-12-2010 2:20 PM
If you still have any left I would like to try one to compare with the netgear router
Regards
Tim
22-12-2010 3:48 PM
23-12-2010 7:39 AM
I'd like to trial one if possible.
I'm having issues with Windows 7 and the Netgear router, it randomly drops the wireless connection and I have to keep manually reestablishing it.
Many thanks,
P.S. my plusnet account is smellycat
23-12-2010 9:33 AM
I'll take one if they are OK with FTTP
Si
23-12-2010 12:25 PM
I'd be interested in trying one although I am not due to be FTTC installed until 30/12. Plus.net have just sent the Netgear but I'd still like to try this one as well.
Cheers,
Si.
PN username: guntons
23-12-2010 6:25 PM
gave a quick try and on my setup seemed to work as well as the netgear, same 26mbs over the wireless link
not tried peer to peer on the lan to see how the max rate goes as i read these aren't great on wireless
- Full Fibre
