FFTP - Can I use my own router ?
robquick
Recently ordered FFTP 900mb, will I still be able to use my own router plugged into the ONT box ?
4 REPLIES 4
Fixes: 530
Re: FFTP - Can I use my own router ?
Yes but seeing as you've ordered the 900Mb product, make sure your router is capable of the throughput..
What router do you plan to use ?
beeceegee
Fixes: 5
Yes, as long as it can be plugged in via an ethernet WAN port, not a VDSL/ADSL port. I use an Asus RT-AX86U
SpendLessTime
Fixes: 86
As the others have said, yes you can ( I do on the FTTP 80/20) but make sure that you get the Plusnet router as 1) a spare and 2) more importantly if you have an issue then Plusnet would be happier to see their router on the line to help diagnose things.
Fixes: 459
Moderators Note
This topic has been moved from Broadband to Full Fibre
