Extension Cable
Birdzilla
Extension Cable
The BT engineer installed my new modem today. The modem is in the hall next to the phone. - not ideal. Can anyone tell me how I can relocate the BT modem upstairs to a better position. Is there an extension cable/kit available?
8 REPLIES 8
jelv
Fixes: 10
Re: Extension Cable
Why didn't you ask the engineer to run a cable and install the modem where you wanted?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Birdzilla
Re: Extension Cable
The BT engineer was very pleasant but insisted that as it was Plusnet he wasnt authorised to do anything apart from changing the faceplate, attaching the BT modem and making sure the phone still worked. Tried showing him the instructions we were given but he called in to the depot and confirmed his instructions.
dave
Re: Extension Cable
I've been on to BT to try and find out why they didn't install the extension kit as we authorise it to be installed on all orders if it's required. They aren't sure and are investigating. I'll let you know when I know.
Dave Tomlinson
Plusnet Technology
Luzern
Fixes: 9
Re: Extension Cable
Asked out of interest or nosiness Undecided Wink
If one has a hard wired extension whose end point is not used for phone, can it be used for the FTTC (kit) in any way at all?
Birdzilla
Re: Extension Cable
Forgot to include before and after figures which are quite interesting as the upload is significantly higher than the download.
help how do you include the speed graphic into a message ?
dave
Re: Extension Cable
If you use mybroadbandspeed.co.uk the easiest way is to click the share link next to the speedtest result and it gives you some URLs you can copy. Pick the forum link one and copy it below like this.
Dave Tomlinson
Plusnet Technology
jelv
Fixes: 10
Re: Extension Cable
The code will look like this:
[url=http://www.mybroadbandspeed.co.uk][img width=200 height=100]http://www.mybroadbandspeed.co.uk/results/61724971.png[/img][/url]
Birdzilla
Re: Extension Cable
Before
After
After moving modem and using long cable
