Dynamic DNS Providers
mcderd
Hello,
I am new here and before I sign up I have a question that Plusnet's support staff cannot sem to answer.
I am going for the Unlimited Fibre Extra and want to know if the supplied router allows setup of a Dynamic DNS service, if so which ones.
Below is a screen grab from my BT router so you can see the settings I am referring to, could someone please be so kind as to list the services offered on the Plusnet router?
Many Thanks
6 REPLIES 6
Fixes: 582
Re: Dynamic DNS Providers
Hi, The PlusNet Hub one is basically the same as the BT home hub 5 so I would see no reason why it would have a different DNS provider list. In any case you could always continue to use your BT hub with PlusNet, you just need to change the username/password in the connection details.
A one off fee of £5 will get you a fixed IP address. You can add one via your account.
Browni
Aspiring Hero
Fixes: 61
Here's one I prepared earlier Smiley
But as @Anonymous points out it's only £5 for a static IP.
mcderd
Good info, thanks
I don't remember having a username and password for BT, or entering in in the router?
From what you have said Plusnet would provide one?
Thaks again.
mcderd
Great info, I did not know that, Plusnet support did not suggest that either.
Many thanks
mcderd
You are correct, it does look like the same options I get on BT router
