Dropped speed
pinkpoy
Dropped speed
I'm in East London, earlier this afternoon my speed dropped from 67mb to barely 2.5mb
I've rebooted the devices connected and it's still slow. Any suggestions on what could be?
thanks
10 REPLIES 10
Fixes: 387
Re: Dropped speed
@pinkpoy This should be on the Fibre Board - I'll see if I can prod the mods  to move it.
In the meantime:-
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection. Please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
pinkpoy
Re: Dropped speed
Fixes: 387
Re: Dropped speed
Thanks for those two @pinkpoy - although the 'Additional Diagnostics' from the Performance Tester would have been more useful.
Have you tried the phone test, and sight of your Hubs Help Desk would be useful?
pinkpoy
Re: Dropped speed
@jab1 - I can't do the 17070 because I don't have a phone.  The other test - additional diagnostic - that is asking for a service ID so I can't run it.
pinkpoy
Re: Dropped speed
Fixes: 387
Re: Dropped speed
OK - no phone s a major issue, because looking at your Help Desk, there is nothing wrong with the speed to your master socket, which does point to a problem on the phone leg of the circuit.
Hopefully, one of the Help Team will spot this and run tests to determine the issue.
Strat
Fixes: 565
Re: Dropped speed
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
Fixes: 479
Re: Dropped speed
@pinkpoy
This is a symptom of one of the two telephone wires to your property being disconnected, hence the desirability of having a dirt cheap corded phone to check. You could try the Plusnet automated phone checker that you can trigger with a text, see https://www.plus.net/help/report-a-problem/phone/
Fixes: 387
Re: Dropped speed
Yep, my suspicion, @Baldrick1 . I must remember the automated checker next  time this happens. 😐
SammyM
Fixes: 101
Re: Dropped speed
Hiya @pinkpoy,
Thanks for getting in touch over forum, I appreciate it and I am sorry you are having issues with your speed.
I have checked the line and it is not picking up an issue on the phone line itself and your speed looks fine from our side.
The best step forward would be to get an engineer out to have a look at what's causing this problem for you, please can you add your availability to the ticket here and come back to me so I can get this booked in for you.
 Sammy M - Sheffield Team
