Drop in speed
d3ck8rd
Drop in speed
Has anyone else experienced a significant drop in download speed this weekend?
My line was installed a week ago, connected my  Asus AX86U router directly to Openreach and setup as PPPoE (partly because the plusnet router didn't arrive for a few days after install).  I've had 500Mb solidly for the whole week across ethernet and Wi-Fi. Since the morning, download speeds have been 80-90Mb/s, I've reset router etc but no luck.
4 REPLIES 4
Fixes: 385
Re: Drop in speed
What happens if  you put the ASUS back in?
Fixes: 581
Re: Drop in speed
Possible cable fault on the cable between router and ONT  ?
80-90 Mb throughput sounds like a cable dropping to 100Mb speed
d3ck8rd
Re: Drop in speed
I didn't stop using the Asus, although I did briefly swap it out with the Hub2 today and the issue continued.
d3ck8rd
Re: Drop in speed
Possibly, it is a flat cable, which can be less reliable. I've re-seated everything and now back up to 500Mb.
I have a new cable arriving anyway so can change it out if it is faulty.
