Drop in speed
fasteasyfree
Drop in speed
Noticed Disney Plus buffering earlier when the daughter was watching it on the telly (wired).
After checking the connection stats on the router, it appears that the downstream connection is at 46.9, whereas previously it was mid-sixties. I've essentially lost 'an ADSL worth' of bandwidth - new unit of measurement!
Was hoping some diagnostics are available to determine what's happened, and how to rectify.
Thanks in advance.
5 REPLIES 5
Fixes: 382
Re: Drop in speed
@fasteasyfree Doubt there will be many PN Help Team about at this time, but if you follow this:-
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection. Please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 1,662
Re: Drop in speed
Thanks for your post @fasteasyfree
i'm really sorry to see you're having speed issues.
I've tested your line today and the tests aren't showing any causes for this, but I can see your download speed is artificially restricted to 49mbps by the automated dynamic line management (or DLM for short) software at the cabinet (the green box in the road), so I've arranged for your line to be reset to remove this restriction.
The line reset should go through within the next 3 working days, however in the meantime I believe there may be another issue here, because at a speed of 46mbps, you shouldn't have any issues even streaming 4K.
Is the TV plugged direct into the router using an ethernet cable or does it go through a powerline adapter or switch first?
fasteasyfree
Re: Drop in speed
Thanks for that. The buffering issue only altered me to the problem, as three of us were streaming at the time, so I'm not concerned there.
I have noticed near the cabinet that a bunch of other cabinets and equipment have also been installed. Not sure if that's related at all...
Fixes: 1,662
Re: Drop in speed
No problem, let's see how things go when your line's reset.
fasteasyfree
Re: Drop in speed
Thanks for the help.
The router is currently reporting 62.25, so I think it's safe to assume the matter is resolved.
