Download speed dropping off every day
- Full Fibre
- Download speed dropping off every day
25-03-2012 9:31 PM
I have been on the trial since Monday. I wasn't really expecting to see much benefit if any at all from my previous 17.1/1 mbps. Started on Monday at 13mbps, improved on Tuesday to 15 mbps, but then started to drop off. Now down to 1mbps.
Message 1 of 4
(1,251 Views)
3 REPLIES 3
Re: Download speed dropping off every day
25-03-2012 10:26 PM
Please try another speed tester - the BT one is absolutely hopeless at the moment and returns under 1 meg for me, while others give 60+. For a really quick test, try http://www.speedtest.bbmax.co.uk/
Message 2 of 4
(346 Views)
25-03-2012 10:34 PM
I normally use the Thinkbroadband test, but posted the results of the BT one because I thought that you had to use that one when reporting a problem? Regardless, whatever test or download timing measurement I do, the fact is that I am suffering from a severe performance degradation.
Message 3 of 4
(346 Views)
25-03-2012 10:58 PM
Quote from: kamho but posted the results of the BT one because I thought that you had to use that one when reporting a problem?
Indeed - that is a bit of an issue at the moment, given the rubbish results that it frequently returns, but Plusnet seems well aware of this.
Message 4 of 4
(346 Views)
- Full Fibre
