Does Plusnet offer the same kind of house coverage as BT?
JJ782
Hello,
I have quite a long flat, and most broadbands don't seem to be able to reach from one end of the flat to the other. I went with BT, because they seem to be the only company able to offer full coverage through out the house, but I am considering switching from BT to Plusnet, now.
Does anyone know if Plusnet's routers are able to offer a full coverage, and if they can be used with a BT booster if necessary?
Thank you for your help,
1 REPLY 1
Fixes: 430
Re: Does Plusnet offer the same kind of house coverage as BT?
@JJ782  Welcome to the forum.
What BT hub are you using? The latest Plusnet Hub Two uses the same basic hardware as a BT Smarthub 2. However there are no satellite mesh units and there are no guarantees on coverage, you get what you pay for I’m afraid. You can add extenders etc from any manufacturer including BT.
If you can keep your BT hardware it can be configured  to work with Plusnet. You will find instructions pinned at the top of the Router board.
