Dimensions of ONT box
mackem1999
Hello.  I’m thinking of upgrading to Full Fibre, but need to decide where to fix the ONT box inside the house. Can anyone please tell me the dimensions of the ONT box - width, height and depth?
6 REPLIES 6
Fixes: 353
Re: Dimensions of ONT box
8cm x 9cm x 3cm.
mackem1999
Thanks John.  Do you have a picture of the box - that sounds very small?
Fixes: 102
@mackem1999
See https://support.aa.net.uk/Openreach_FTTP_ONT
Might be a slightly older version but basically it's about the size of a wall mounted phone or power socket.
Fixes: 353
Yup
mackem1999
Many thanks. That's much smaller than I anticipated.
mackem1999
