Developments in FTTP service provision
- Full Fibre
- Developments in FTTP service provision
22-10-2018 10:36 AM
Openreach to Stop Providing Battery Backup for FTTP Broadband
Makes me even less likely to want FVA.
Re: Developments in FTTP service provision
22-10-2018 11:16 AM
I don't have (and don't need!!!) FVA so the battery backup I have (old style separate from the ONT) is just an eyesore.
The OpenReach decision makes sense as I suspect a significant number of FTTP users will not use FVA. Those who do would need battery back up for their router anyway so can buy a unit that suits them and covers both ONT and router.
22-10-2018 11:36 AM
Likewise, except that my BBU is still in it's box unused, sitting on a shelf.
22-10-2018 11:53 AM
If I knew then what I know now then not only would the battery back up still be in its box ( as would my neighbours) but the ONT itself would be in a different place.
22-10-2018 12:27 PM
If I ever have the desire to move my ONT then that would be relatively easy because I have approximately 25m of the internal fibre cable coiled up under the floorboards just below where the ONT is mounted. The original run was approximately 3m from my internal CSP (run through my pre-installed conduit) but the BTOR installer was happy to leave the excess from the 30m coiled up for me when I suggested it would then make it easy/cheap to 'self-move' the ONT if I ever need to.
The connectorised end of the cable runs through a short length of conduit (25-30cm) from under the floorboards to an outlet below the ONT, so easily pulled back and rerouted (obviously taking care to protect the optical connector from dirt or scratches).
- Full Fibre
