DNS to block adverts on Sony Smart
- Full Fibre
- DNS to block adverts on Sony Smart
15-12-2021 4:39 PM
Is there a way to change the DNS server settings on the plusnet hub one ?
Re: DNS to block adverts on Sony Smart
15-12-2021 4:48 PM
there is no option on the Hub One to make this change.
You need to use a 3rd party modem/router.
Dan.
15-12-2021 5:06 PM
@andrewsimpson70. but you could probably set the DNS on the device (TV?).itself https://www.sony.co.uk/electronics/support/articles/00125843
Use an ip address out of the router dhcp range, assuning the router is set to defaults, use something between 192.168.1.1:and 192.168.1.63
- Full Fibre
