Current line speed
Temple1970
Current line speed
Hello,
So my Plusnet Fibre has been up and running for 2 months. No issue what so ever however my line speed on the Plusnet Broadband page seems incorrect.
My Fritzbox stats state the following
Attainable throughput    kbit/s     Down 80019                   Up 18745
Current throughput        kbit/s               79979                         18744
My Plusnet stats page shows
Current Line Speed (Download): 72.6Mbps
The Bras IP profiles Shows
The current Downstream IP profile rate is: 73.58
The current Upstream IP profile rate is: 20
My question is why are both the Plusnet and Bras Ip profile displaying different figures to my Fritz and which should it actually be?
Cheers
2 REPLIES 2
adam945
Fixes: 113
Re: Current line speed
Thanks a lot for getting in touch @Temple1970
Apologies for the confusion caused here. As you have a static IP on the account, you're connected via L2TP, which means your connection speed is not only influenced by the Openreach's DLM profile, but is also affected by our internal Workplace profile. Our internal profile does it's best to say in line with the current line speeds, though it can sometimes lag behind.
Going forward, I've reset the connection profile on our end, so you should see that it's now in line with the current sync speed. I've also run a line test and will pop it below. Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 76.0 Mbps
Upstream Speed 18.7 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 496.7
Upstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed on Week Days
Service Impact Retrains Observed
Interference Duration Longest Occurrence From08:00to08:15
Interference Location Customer Premise
Interference Observed In Days 0
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2022-01-06T10:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.7 Mbps 79.9 Mbps 79.9 Mbps
Up Stream Line Rate 18.5 Mbps 19.6 Mbps 19.1 Mbps
Up Time 0.0 Sec 900.0 Sec 898.3 Sec
Retrains 0.0 4.0 0.0
 Adam
 Plusnet Help Team - Leeds
Temple1970
Adam,
Many thanks for clarifying the confusion.
Cheers
