Current Firmware for WNR1000v3
- Full Fibre
- Current Firmware for WNR1000v3
14-02-2012 8:33 AM
What's the current version of the Plusnet supplied router WNR1000v3 that people are running ?
I currently have V1.0.2.30 and i see that there is V1.0.2.42 available on the Netgear website here: http://support.netgear.com/app/answers/detail/a_id/19828/~/wnr1000v3-firmware-version-1.0.2.42
When i tried to upgrade it to the WorldWide version I got the following message:
Router Upgrade
Warning! You are trying to download the firmware which the region is different from the current firmware you had.
Do you still want to continue?
Current Firmware Version V1.0.2.30_53.0.66B1
Uploaded Version V1.0.2.42_55.0.77
Any thoughts ? Any one used this version ? Is there a different version i've missed ?
Thanks ... Andy
Re: Current Firmware for WNR1000v3
14-02-2012 9:00 AM
If you're trying to upgrade the firmware you may hit some problems as I've been made aware that they're locked down to stop you from being able to do that.
14-02-2012 9:29 AM
I'm also pretty sure that i upgraded this once already.... but not 100% sure on that .... age if you know what i mean
14-02-2012 9:48 AM
14-02-2012 9:50 AM
if anyone has updated, please let me know ...
Andy
14-02-2012 4:08 PM
There's another thread (in 'Broadband & Routers' I think) that deals with problems people have had with v1.0.2.42 - wireless connectivity problems. The 'different region' issue you mention may have something to do with that.
Anyway, if 1.0.2.30 is what Bob's running, I'm not going to worry about upgrading, especially as I've not had any problems with the router so far.
Graham
14-02-2012 4:21 PM
14-02-2012 5:12 PM
1 - I'm having problems with IPv6 in my home network and 42 seems to have IPv6 changes in it, but this may not be my problem anyway.
2 - I like to keep FW software up to date as it's protecting my home network
What I don't want is the problems others are reporting with 42, so I think I'll stay with 30 for the moment.
Andy
12-03-2012 10:32 AM
i downgraded the firmware to WNR1000v3-V1.0.2.18_47.0.52.chk from the plusnet firmware. but it made no difference
But I now cant get back to the latest WNR1000v3-V1.0.2.28_52.0.60.chk firmware.
the router keeps saying 'firmware upgrade failed. please check your file'
i have tried :-
pressing reset button for 30 secs
pressing reset button then powering unit up and holding for 30 secs
every firmware available for the v3
using firefox with java disabled.
pressing wifi and wps buttons together with unit powerd off, and then powering on.
The auto check detects the new updated file on netgear website but produces an -1 unknown error
downloading firmware file by other means.
i also used a direct ethernet cable to router.
could someone post a link to new or older plusnet firmware please, the netgear link is down, maybe for the ipv6 problems reason
or could give me a clue how to get the router to accept new firmware.
cheers
14-03-2012 11:49 AM
18-05-2012 11:49 AM
18-05-2012 5:42 PM
However, the version that came with Plusnet's router last August is 1.0.2.30. People above have clearly found other versions - but maybe these are for the v2?
Graham
19-05-2012 9:27 AM
As far as the Netgear issued firmware goes the current version is V1.0.2.28 (if you click on it there are different links for US and non-US on the page). There was a newer version available for a while (v1.0.2.42) but that was removed from the site a short time after it was released, probably due to the stability issues that have been reported. When I last looked ages ago it was still available on their ftp site if you have a dig around.
The v2 router is a totally different beast (in terms of both hardware and firmware) but to confuse things a bit more I think some were issued along with the v3 version during the FTTC trial - not sure on the firmware versions for those.
20-05-2012 2:14 PM
Graham
20-05-2012 7:17 PM
It may well be that the Plusnet firmware is effectively the same as or newer than the standard Netgear release - I would not take the release/build date as a definite sign it is not (the updated firmware could have been internally available for some time before it was actually released). It would be nice to get a definitive answer on that though especially if anyone is experiencing issues that they may think are fixed in the standard firmware.
- Full Fibre
