Could someone from Plusnet please help me?
- Full Fibre
- Could someone from Plusnet please help me?
08-08-2012 9:29 AM
Recently signed up to the 80 trial. This morning I noticed the upload speed has increased but the download speed is the same as it was on 40.
I've done the usual things such as reboot the modem and router, etc.
Would you be able to look into this / or advise me on other things to try?
Best,
Rob.
Re: Could someone from Plusnet please help me?
08-08-2012 12:02 PM
08-08-2012 12:26 PM
Current speed reading as 20mb.
Best,
Rob.
08-08-2012 12:30 PM
08-08-2012 12:36 PM
Thanks for your replies!
I'll let you know what it comes back with when I get home from work - around 6ish.
Rob.
08-08-2012 6:23 PM
The line profile is 33.88 which is the sort of speeds I was getting on 40.
Any suggestions?
Rob.
09-08-2012 7:13 AM
Do you have any idea how far you are from your green fibre cabinet?
The people that seem to have the greatest benefit on the 80/20 are those that were getting full speed before the trial i.e 37meg ish. The trial just removes the cap allowing full speed down the line.
Its possible if you were only getting 33 meg before that could be the maximum your line can handle and as such joining the trial and removing the cap will have little to no effect on your download speed.
Regards
Paul.
09-08-2012 10:02 AM
Just noticed that the plusnet line speed is now 37mb.
Does this have any bearing on things?
Rob.
09-08-2012 11:08 AM
09-08-2012 3:27 PM
Here's a grab just prove I'm not mad!
15-08-2012 1:18 PM
Downstream Speed 35.0 Mbps
Upstream Speed 7.2 Mbps
With a BT Wholesale profile of:
17.5M-35M Downstream, Interleaving Low - 3.6M-7.2M Upstream, Interleaving Off
That's pretty consistent with an availability check here.
I've changed your profile our side to match this.
- Full Fibre
