Connection drops out in the evening
Jawoc
I appear to have a problem with the internet in the evening. I would guess it's most apparent around 8pm 'ish. Last night we gave up watching streamed TV as a result.
I thought I would investigate this morning to see if there are any planned outages, e.g. for maintenance, but I can't get the service status page (https://plusnet.servicestatus.net/plusnet/status) to load, it just times out. Other websites are fine.
Can anyone shed any light on what is happening? Thanks.
10 REPLIES 10
Fixes: 383
Re: Connection drops out in the evening
@Jawoc First question - are you actually on Full Fibre, or Fibre To The Cabinet?
Planned maintenance is not performed at peak times - usually between 0100-0600.
Jawoc
Hi John,
I'm on Full fibre, specifically Plusnet's Full Fibre 74 plan.
Fixes: 383
OK. I'll leave this to others, then. Not up to date on FF, but just one question - are you doing anything else at the time, watching TV alone, especially on FF, shouldn't have this effect?
Jawoc
John,
One of the kids may well have been using their smart phones for social media etc, but I can't imagine that would present any problem for the connection. I certainly can't think of anything as bandwidth intensive than the streaming TV we were trying to watch. It's not the first evening that this has happened either.
Fixes: 383
Fair enough - was just a thought, but as you say, that shouldn't cause problems - I can have two laptops and an iPad running happily on a 40/10 FTTC connection.
RobPN
Fixes: 15
@jab1
ICBW, but I suspect that, as has turned out to be the cause in numerous other threads, that there will be nothing wrong with the connection, but that WiFi will be once again demonstrating its shortcomings. Wink
Jawoc
Hi Rob,
It has crossed my mind as well. I think this weekend I shall run a temporary network cable to the TV to see if that cures the problem.
Jawoc
Hi Rob,
Fixes: 383
@RobPN wrote:
@jab1
Good point, Rob - the thought had crossed my mind. Suppose it depends how far the TV is away from the Hub.
Jawoc
The hub is approx 5-6 metres above the TV (terraced house, hub is upstairs in front room near the bay window, TV is downstairs in front room near the bay window).
