Connection dropping, guest unable to connect, connected with no internet.
- Full Fibre
- Connection dropping, guest unable to connect, conn...
04-10-2021 8:25 PM
Occasionally I am connected but told no internet. What is the problem with Plusnet? I'm obviously past the grace period to reverse my contract and I'm not really happy with the service, yet I fear I have to stay or pay the penalty for early disconnection.
Re: Connection dropping, guest unable to connect, connected with no internet.
04-10-2021 8:32 PM
@virgopearl Welcome to the forums. I know you have said you have been here 'just over a month', but I'm wondering from the problem description if you are properly authenticated. What does the router Help Desk page show as your user name?
05-10-2021 1:50 PM
Hi @virgopearl,
I'm sorry to hear that you've been experiencing issues with the Wi-Fi connections. I've had a look into your account and upon testing the line we're not detecting any particular issues with the setup, nor any underlying faults. As this is the case, I'd ask if you're able to try connecting via Ethernet cable to see if this makes any difference? As for the wireless side of things, I'd recommend splitting the networks that your router is operating on and we have a guide on how to do this here. I'd also recommend giving this a read as it may help.
05-10-2021 2:52 PM
05-10-2021 6:17 PM
07-10-2021 6:36 PM
08-10-2021 10:10 AM
Thanks for getting back to us @virgopearl
Appreciate that but there's a lot of environmental factors that can affect the wireless signal around your home.
Are the devices connecting onto the 2.4GHz or 5GHz wireless frequency when they're having issues?
If you've split the frequencies then you can connect to either one by going into the list of wireless networks on the device.
We're just trying to help you get to the bottom of the issue. ![]()
- Full Fibre
