Connected but TV just buffers
- Full Fibre
- Connected but TV just buffers
28-01-2026 8:11 PM
During the day however it’s absolutely fine, does anyone else experience this ? Or have a solution ?
Thanks.
Re: Connected but TV just buffers
28-01-2026 8:17 PM
Which version of fibre do you have?
28-01-2026 8:19 PM
28-01-2026 8:20 PM
What have Plusnet support told you?
28-01-2026 9:04 PM
Moderators Note
This topic has been moved from Broadband to Full Fibre
28-01-2026 9:37 PM
@Sam1986 Welcome to the Plusnet Community Fora.
Is your router connected to your TV using an Ethernet cable or over a wireless link? I ask because this sounds like a wireless problem. Have you tried rebooting the router during periods when you are having buffering?
29-01-2026 7:56 PM
31-01-2026 11:35 AM
Welcome to the Community, @Sam1986.
If you haven't already I'd definitely recommend trying the reset on your Hub like @Baldrick1 has mentioned here.
Once you've given that a try, if you're still having issues there are a few more steps you can try on our help page here, and if needs be details on how you can log this as a fault with our team.
Peter
31-01-2026 3:20 PM
TV streaming takes much more bandwidth than phones and potentially working from home. Have you tried a speedtest on a computer located next to the TV? Try it and report back.
Have you checked your download speed with a computer connected to your router via an Ethernet cable? If so, what is it and how does it compare with the minimum guaranteed speed quoted in your contract? If you are exceeding the MGS then there’s no point in reporting a fault.
The reason that I suggest a reboot is when you are having problems is that you may have poor wireless performance due to co channel interference with a neighbour’s WiFi and a reboot might trigger your router to change channel.
02-02-2026 2:27 PM
I’ve had to ring up twice over the weekend, I’m being sent a new router, we have to reset it everyday to get anywhere with the TV streaming, last night however was the worst yet, the reboot didn’t do any good at all.
Very frustrating….
03-02-2026 10:06 PM
07-02-2026 8:43 PM
Complaint going in…
07-02-2026 9:36 PM
@Sam1986 wrote:
... the TV or Roku box will not connect to the WiFi ...
Complaint going in…
Good luck with that ![]()
WiFi is not the ISPs responsibility.
10-02-2026 7:40 PM
Very unimpressed though, never had this issue with any other provider not great you get locked in for 2 years either.
10-02-2026 7:48 PM
@Sam1986 It is NOT the router - as such - it is more that the 'Smart' function, as on a number of routers - is not that 'smart' and will select a congested channel which it is reluctant to give up.
- Full Fibre
