Congestion in MK ?
SpendLessTime
Fixes: 86
Congestion in MK ?
Slow tonight on FTTP 80/20 link
12 REPLIES 12
SpendLessTime
Fixes: 86
Re: Congestion in MK ?
You are currently connected to gateway pcl-ag01.
Speed tests down from wired PC, no other traffic. Been on this gateway for 40 odd days, no issues like this.
AndyH
BTW have repeatedly said they see no issues with capacity in MK - I disagree with them as I've begun to see signs again.
My Samknows box is showing a drop to around 65Mbps, but not below the 60Mbps threshold.
chrcoluk
Hop gateways, the few times I have had to gw hop for performance, by coincidence its pcl-ag01 I had to hop away from.
SpendLessTime
Fixes: 86
Switched to ptn-ag04 and will see what happens tonight.
Ping times to speedtest.net and thinkbroadband are slightly lower post swap then just prior.
Pings to bbc.co.uk are the same.
So wait and see.
AndyH
What did your graph look like last night?
Mine was very strange:
I was out for most of the evening so the connection would have been idle.
SpendLessTime
Fixes: 86
Yesterday was
Nothing out of the ordinary.
Edited as I had put in a live graph!
SpendLessTime
Fixes: 86
Everyone must be watching the football/Star Wars/Twilight currently  Smiley
SpendLessTime
Fixes: 86
Football final whistle and Star Wars finished
TBB looking good
But the QM is showing a large number of dropped packet occurrences on this gateway "ptn-ag04". Was only getting 1 or 2 dropped packets a week on "pcl-ag01"
SpendLessTime
Fixes: 86
Just changed gateway onto  pcl-ag02 to see if the dropped packets go away. ptn-ag04 was showing too many dropped packets overnight with zero usage.
Now wait to see if the situation improves.
Edit to add TBB and speedtest.net results post gateway change
SpendLessTime
Fixes: 86
First time I've seen this on any gateway. Minimum latency increases when 2 or more devices on on-line at the same time.
Still on pcl-ag02
SpendLessTime
Fixes: 86
Congestion again
SpendLessTime
Fixes: 86
Still on pcl-ag02 but since yesterday at 6:45am, the TTB QM now shows a constant minimum latency, use of the line is no longer increasing the minimum latency figure.
