Can't access EuroCarParts or Carparts4less
S65v10
No idea why?! When I turn on windscibe vpn it works so must be ip related?
I saw another post about this so not sure what the fix is?
4 REPLIES 4
Fixes: 334
Re: Can't access EuroCarParts or Carparts4less
@S65v10 The chances are, from my experience, that the said companies are using an out-of-date/incorrect IP location service which will show your IP to (probably) be in the USA.
If you enter your IP into Where is my IP location? (Geolocation) what results do you get?
S65v10
You are probably right, all other websites work like GSF.
IP shows as King Sutton. I'll just use VPN for them, just wanted to check prices.
Fixes: 334
@S65v10 Not trying to blow my own trumpet, but I'm 99.9% sure I'm correct - I was quite involved with a thread re: these two company's a while back. Seems they still don't like paying for up-to-date databases.
S65v10
Yeah thanks mate, luckily I can just use the built in vpn on the Opera browser and works fine.
