Can I take part in the FTTC trial?
jonould
Dave,
I've just raised a ticket number 36703126. Please use the mobile number in that ticket to contact me.
I can be availiable most m ornings if the window slips beyond the 2 weeks I've already detailed.
I have an existing Netgear DG834N if that will work.
Cheers
Jon
1 REPLY 1
dave
Re: Can I take part in the FTTC trial?
Hi Jon,
I'll be going through the tickets over the weekend so will pick it up then for you. The Netgear DG834 series of routers isn't compatible with FTTC. FTTC needs a router with an Ethernet WAN port rather than a DSL port. Most cable routers like the Netgear WNR1000 router we're supplying work fine but most ADSL routers won't work. Happy to send the WNR1000 for free.
Dave Tomlinson
Plusnet Technology
