Broadband speed drop
- Full Fibre
- Re: Broadband speed drop
11-12-2021 10:59 AM
3 months ago my broadband speed was 28mbps it has been steady at around 20+mbps for approximately the last 2 months, since accepting a new contract a few days ago it has dropped below 18mbps. I have reset the router, powered off for a few minutes no change. Can you have a look please?.
Mick
11-12-2021 11:21 AM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
11-12-2021 11:34 AM
@mickatmian Welcome to the forums. Hopefully one of the Help Team will pick this up at some point, but:
For Community members to be able to help, information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
11-12-2021 12:04 PM
Thanks jab 1
BTW Performance tester 17.57mbps download 6.16 upload no faults showing today but was showing faults a couple of days ago.
Quite line ok.
Line tester?
| Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper | ||
| High | Low | High | Low | |||||
VDSL Range A (Clean) ![]() |
34.7 | 22.4 | 7.1 | 5 | 20 | Available | Available | -- |
VDSL Range B (Impacted) ![]() |
34 | 20 | 7 | 4.7 | 16.5 | Available | Available | -- |
| Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process |
| FTTP on Demand | 330 | 50 | -- | Available | -- |
| ADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | ADSL Availability Date | Left in Jumper |
| WBC ADSL 2+ | Up to 2.5 | -- | 1 to 4 | Available | -- |
| WBC ADSL2+ Annex M | Up to 2.5 | Up to 0.5 | 1 to 4 | Available | -- |
| ADSL Max | Up to 2 | -- | 1 to 3.5 | Available | -- |
| WBC Fixed Rate | 1 | -- | -- | Available | -- |
| SOADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | WBC SOADSL Availability Date | Left in Jumper |
| WBC SOADSL 2+ | Up to 2.5 | -- | 1 to 4 | -- | -- |
| SOADSL Max | Up to 2 | -- | 1 to 4 | -- | -- |
| SOADSL Fixed Rate | Up to 1 | -- | 1 to 3.5 | -- | -- |
| Observed Speeds | VDSL |
| Max Observed Downstream Speed | 19.99 |
| Max Observed Upstream Speed | 6.33 |
| Observed Date | 2021-12-10 |
| Other Offerings | Availability Date |
| VDSL Multicast | Available |
| ADSL Multicast | Available |
| Premise Environment | Status |
| Bridge Tap | N |
| VRI | N |
| NTE FacePlate | N |
| Last Test Date | 01-12-2021 |
| Exchange Product Restrictions | Status |
| FTTP Priority Exchange | N |
| WLR Withdrawal | N |
| SOADSL Restriction | Y |
The exchange is not in a current fibre priority programme
Thanks for looking
Mick
11-12-2021 5:08 PM
Not sure what happened but I posted the requested information around 4hrs ago, but it's not showing.
Can someone look please?
Mick
11-12-2021 5:22 PM
@mickatmian Wonder if it's been caught by the 'spam filter' - it happens sometimes, maybe @Strat or @dvorak can check?
11-12-2021 5:37 PM
Moderator's note by Dick (Strat): Message 4 above released from Auto Spam Filter.
11-12-2021 5:44 PM - edited 11-12-2021 5:45 PM
@mickatmian Thanks for those details, although a screenshot of the BTW Performance Tester is a little more informative than just posting the figures you have - there is detail there which can be useful.
Don't understand your Line tester? query, and you have missed the Hub Help Desk page which is also very useful.
You are obviously a long way from the VDSL box, as you were from the exchange. Are you very rural?
12-12-2021 10:46 AM
@JAB 1
I am approximately 1k from the VDSL box (fibre box?) and 4k from the exchange so yes very rural. For information my neighbour 80 M further from the box almost never has a problem and constant speed around 24mbps he is with BT not that it should make a difference.
For information.
I have been with Plusnet for a number of years during which time I have had an untold number of Openreach engineers visit the last of which (3months ago) said a section of the copper line had been replaced, the line in was clear and around 31mbps, He also checked my house wiring, box etc no faults, but suspected the router was faulty. Plusnet insisted it was not faulty and reset it from their end which gave me a speed of 28+mbps so I guess the Plusnet engineer was correct. when the router speed dropped to 20ish mbps I contacted Plusnet and was told the line speed was showing 31mbps but as I was still getting more than my 15mbps guaranteed speed they would not do anything! Pathetic really.
I have reset the Hub 1 router etc. before posting. Not sure if it needs a firmware/software update.
I mistakenly? thought the test you asked for was a line test sorry.
Thanks for your help
Mick
As requested
12-12-2021 11:08 AM
Mick, looking at that BTW report above, you should really be getting around the 30Mb/s mark. Distance from the exchange is irrelevant, but over half a mile from the cab will reduce your speeds. Can't remember the distance/speed reduction correlation off the top unfortunately.
The final piece of the jigsaw - for non-PN people to help - is your Hubs Help Desk page - the picture below should help you find it.
12-12-2021 12:22 PM
Thanks John.
Will try your suggestion later as F1 has just started.
Mick
13-12-2021 1:53 PM - edited 13-12-2021 1:53 PM
Thanks for your post @mickatmian
I'm sorry to see you're having speed issues. I've tested your line today and the tests aren't showing definitive causes for this but I can see your speed is artificially restricted to 20mbps by automated software at the cabinet (the green box in the road) so I've arranged for your line to be reset.
This should go through within 3 working days and you should see an improvement afterwards.
13-12-2021 2:07 PM
Thanks Gandalf
For information the last Openreach engineer said the line was showing clear and removed the cap (around 3 months ago) which gave me a speed around 29mbps so not sure how the cap is back to 20mbps.
Will see what happens.
Mick
13-12-2021 5:02 PM
Hello @mickatmian
DLM is automatic, it's software which will cap the line if it finds that it's unstable. This will explain why the cap was lifted, but has been put back on. If DLM detects quite a few drops on the line, it'll slow it down to preserve stability. ![]()
13-12-2021 5:53 PM
Hi Adam,
Yes I am aware of that, but a drop from 29mbps to 17mbps is unacceptable. Neither does it explain why my neighbour (80M) further from the cabinet has a constant speed around 24mbps.
Mick
