Block Wifi at Night - Using Router Plusnet Safe Guard or another method?
- Full Fibre
- Block Wifi at Night - Using Router Plusnet Safe Gu...
- « Previous
- 1
- 2
- Next »
Re: Block Wifi at Night - Using Router Plusnet Safe Guard or another method?
22-02-2016 12:15 PM
Quote from: Anotherone 1) ... Turning off a separate router should not be an issue. If the modem is maintaining sync, DLM doesn't even enter the picture.
But how long would the modem retain sync for when the router was off, could it really survive 7+ hours?
Is there not some form of Ping Pong between the two devices. i.e. Router to Modem Are you there? Modem to Router Yes. Or indeed vice-versa.
Message 16 of 18
(3,861 Views)
22-02-2016 12:27 PM
No there isn't. Sync should be maintained continuously until some external factor affects it - power cut, major interference or other fault on the line etc.
Message 17 of 18
(3,861 Views)
22-02-2016 12:44 PM
That's good to know, thanks for that.
Message 18 of 18
(3,861 Views)
- « Previous
- 1
- 2
- Next »
- Full Fibre
