BT Modem problems
timsheffield
BT Modem problems
Has anyone else had a problem with the LAN port on the modem Mine seems to be a bit hit and miss with the conection of the network cable?
2 REPLIES 2
G3YBO
Re: BT Modem problems
Hi........So far no problem with mine here......BT on fitting said must be mounted on a wall, maybe a heatsink idea.....It does
run warm but not hot.....Not had summer yet so maybe will increase when it comes......The Netgear router runs colder than
my first one a few years ago.......So far FTTC has been very good 37 Mb down and 8 Mb's up.....Pleased to see Plusnet have
increased my limit to 120Gb.......At 60Gb I was  just over some months.....Yes the cost is up with FTTC but you get what you
pay for.....
Regards
Roger
Peter_Vaughan
Could be a bad network cable.. have you tried another cable.
Some BT modems do get very hot and stop working. Maybe you have one that suffers this... mounting on the wall may improve heat dissipation and make it more reliable.
