Are these the correct speeds
EDD1
Hi upgrade to Fibre Extra and seems slow.  It says on USWITCH SPEED TEST DOWNLOAD 4.8 MPS and on BT test 4.93 MPS. My account shows i am still on Broadband unlimited which i am not
13 REPLIES 13
Fixes: 357
Re: Are these the correct speeds
@EDD1 Those speeds do seem slow. Can you do the 'Additional Diagnostics' on the BT test, please?
When did you switch to Fibre Extra, and have you had confirmation that the order has completed?
EDD1
hope this is what your looking for. was upgraded on Wednesday
Fixes: 357
That is what I was looking for, thanks - it proves your upgrade is not completed. You need Help Team intervention.
Mustrum
Fixes: 81
It looks like you are still on ADSL, or that is all your line will support.
If you enter your phone number into the BTW DSL checker I should give us a bit more of an idea.
If you could post the results, but hide your phone number.
EDD1
Fixes: 357
Well, you can get Fibre to the cabinet at a reasonable speed, but you are still on ADSL.
What communication have you had from Plusnet over this matter?
EDD1
more information
LaurenB
Fixes: 131
Hiya @EDD1, thanks for getting in touch. I am sorry to hear your speeds haven't yet increased as expected.
I have provided a further response regarding this here for you: https://www.plus.net/wizard/?p=view_question&id=218405228
 Lauren Barry
Fixes: 357
@LaurenB Not that this is any of my concern, but if a customer posts on here and gets a Community response, would it not be an idea to give those Community members an idea of the issue - unless of course it is a 'commercial secret'?
198kHz
Fixes: 42
Agreed, @jab1
Too often we see a response such as
which should only be necessary for account/billing matters.
BT technician (Retired)
adam945
Fixes: 113
Hey @198kHz and @jab1
While we did request a particular activstion date for a fibre service to become active, these orders are subject to engineer availability and can be pushed back. This is what has happened here. Smiley
 Adam
 Plusnet Help Team - Leeds
Fixes: 357
Thanks @adam945 - so not commercially sensitive, and a straight answer on the forums would have saved us wondering.
198kHz
Fixes: 42
Thanks @adam945
Seeing tech matters through to a resolution helps us to help in the future. 🙂
