AppleAirplay via Plusnet hub
naggeddad
just moved to Plusnet with Plusnet hub, Apple Airplay connects to the Apple TV and  I can see my phone screen via screen mirroring but it was not play or stream a film or TV,
Worked on BT hub but not on Plusnet, Feels like a setting on the hub but Any help would be great Thanks in advance
4 REPLIES 4
Mustrum
Fixes: 81
Re: AppleAirplay via Plusnet hub
Why not use the BT Hub, you just need your PN username and password?
PN hubs are based on BT ones, the settings are the same. Which version of each Hub do you have?
naggeddad
hi
thanks
I have a hub 2
I tried the advanced setting and changing the PN and password but no joy
everything else works but it will not stream to the appleTV ?
Fixes: 1,652
Does the Apple TV give an error message of some description when you try to stream?
Fixes: 1,491
Airplay is working fine from my phone to Apple TV
