Anyone got FTTC to work at 4.2km from cabinet?
- Full Fibre
- Anyone got FTTC to work at 4.2km from cabinet?
07-03-2011 10:36 PM
I'm interested to know if anyone has successfully connected via fttc with a line length of around 4.2km to the cabinet? This is what I have and it doesn't seem to wok because of the distance to the cabinet.
Message 1 of 6
(1,843 Views)
5 REPLIES 5
Re: Anyone got FTTC to work at 4.2km from cabinet?
07-03-2011 11:27 PM
Beyond 1.6KM, the VDSL2 (FTTC) speeds are no better than the equivalent ADSL2+ speeds. Once you go beyond 2.5KM then speeds can be below the min FTTC threshold of 5Mbs (it used to be 15Mbs) that BT require to allow them to consider an FTTC connection. I doubt you will get it at 4.2KM.
Message 2 of 6
(497 Views)
08-03-2011 9:00 AM
OK, thanks for that....I didn't realise there was a threshold for the FTTC. I wouldn't care if the speed was 1 Mb, any internet connection that works would be great right now!!
Do you know if they can run it at a lower speed?
Message 3 of 6
(497 Views)
08-03-2011 11:31 AM
I'm surprised that BT even took this on, I would have thought their database should have chucked it out with a line length like that.
I thought that I had seen somewhere that the lowest target speed for download sync was 10mbs (or was it 15mbs) and wouldn't be provisioned if that wasn't reached...could easily be wrong though
Message 4 of 6
(497 Views)
08-03-2011 7:06 PM
When the FTTC trial started BT had a min of 15Mbs before considering FTTC for a line, this was recently reduced to 5Mbs.
Message 5 of 6
(497 Views)
08-03-2011 8:00 PM
Presumably this is done so everyone is paying for a minimum speed as part of their package? Is it possible to have the speed throttled back so that will work over a longer distance?
Message 6 of 6
(497 Views)
- Full Fibre
