And still, a big NOTHING.
- Full Fibre
- And still, a big NOTHING.
25-08-2015 7:21 PM
I realise that this is a trial etc etc, blah, blah blah. But come on, this is simply unacceptable. How hard can it be to just let me know that they cannot get a date from OR (if that is indeed the issue). I'm simply getting nowhere and I'm getting more and more pissed off at PN treating their long standing customer in this way.
I just don't know what to do now. There is fibre in the road outside and it's all ready. I have placed the order. I was told a date. I waited for that. On checking this again I was told it had to be delayed and since then, I might as well be speaking Martian. I've been patient, but this is beyond a joke. WTF is going on? I deserve to be kept informed.
Re: And still, a big NOTHING.
26-08-2015 11:20 AM
What do I have to do to get someone to actually answer me?
26-08-2015 11:42 AM
Quote from: UKenGB What do I have to do to get someone to actually answer me?
Migrate to a different ISP!
26-08-2015 12:11 PM
dick:quote
26-08-2015 10:40 PM
27-08-2015 11:51 AM
Finally yesterday, after phoning PN I was told trees have been trimmed (news to me) and the external install would be actually 2 days hence, on the 28th which is now tomorrow. Surprise surprise, he turned up this morning (27th) and announced the trees had not been trimmed. But when we discussed this and he showed me some HYBRID cable with a copper pair AND the fibre, it was decided to replace the current hanging copper with this, so it could just be pulled through the trees with no trimming needed - which is EXACTLY what I had suggested in the first place, when it was first delayed.
So I'm not unhappy that he came a day early and we've been able to work out a solution (the engineer is being extremely helpful), but how hard can it be to agree a schedule and then stick to it. If I had not been here, it would all have been done wrong, because...
Unbeknownst to me, the CSP has to be at knee height, or at least, no higher than can be accessed standing on the ground. But I need it up under the eaves where the copper cable is currently joined and have installed internal wiring to suit that, only to now discover this cannot be done. Everything I know about FTTP, I have had to dig around and find out for myself. Those involved in installing, promoting and offering their services over it should be ashamed of themselves for keeping customers so in the dark. Fortunately I'm sufficiently technically competent to find out these things, but NOWHERE did I see anything about the height limitations of the CSP. So beware.
In the end we agreed the CSP could be placed inside and run the external fibre through the wall, which was easy due to there being a conveniently located air brick and ultimately it will all be hidden by the curtain. But if information was more forthcoming, there wouldn't need to be any such re-planning at the eleventh hour.
Most impressive is how having got the fibre tubing in place, he blew it in from the road and after only a few seconds it came snaking out of the cable/tube. Clever stuff.
Anyway, come later today, the external will be complete (and to my satisfaction:-). So then I'll just be waiting for the internal install work. Scheduled for one day next week, but looks like I'm going to have to be ready the day before - just in case.
dick:quote
27-08-2015 12:58 PM
Quote from: UKenGB
Well you appear to have reached a suitable compromise and now have the fibre installed to your internal CSP, so with a bit of luck you should be up and running fairly soon.
Reading the right threads here and elsewhere would have pointed you to the Openreach Developers Guide which would have provided you with the information you mention above, including the fact that the external BFT is not supposed to be routed indoors for more than 2m without being enclosed in metallic conduit due to fire safety rules.
Being aware of that fact enabled me to prepare for my FTTP by installing said conduit (with draw rope) from my proposed entry point above a first floor window, through my loft, down through a chased-out wall, under a floor, then down to a utility cupboard on the ground floor, some 18m. My internal CSP is actually screwed to the wall approx. 1.5m above floor level.
The internal fibre was then pulled through a second conduit from my computer room upstairs above the cupboard down to the CSP to be spliced. At my request the engineer kindly left the excess 20+m of internal fibre coiled under the floorboards in case I ever wanted to move the ONT (which I could do by unplugging the fibre from the ONT before carefully pulling it through conduit again to its new location). The job was completed without using a single cable clip and the only visible fibre is about 10cm where it emerges from the wall and plugs into the ONT.
Regarding your questions elsewhere about FVA, that subject came up when I was chatting to the OR engineer who did my second stage fitting. He told me some interesting stuff about the ONTs and exchanges;
1. Apparently the type of ONT supplied to me is not enabled for FVA even though it has 2 telephone ports.
2. Not all exchanges (including mine) are enabled for FVA.
Good luck with your second stage appointment.
27-08-2015 4:23 PM
My complaint on here was largely about PN's bad communication and customer service about my order, but it looks like it has just been bad communication and the process has been churning away, as I hoped. But OR themselves don't seem to know whether they're coming or going. Everything they have said has been inaccurate. If I wasn't as technically minded as I am, there isn't a cat in hell's chance of being able to figure out what's going on. It seems to me the entire fibre rollout is being handled very shoddily. This is not directed at PN, but squarely at OR as they are the ones in charge of that.
We had flyers put through our door over a year ago extolling the virtues of fibre, when it was completely impossible to get it, there wasn't any. Once they actually had laid the fibre, we got another flyer, but the checkers still said not possible and NOWHERE was there any mention of FTTC or FTTP, so no normal person would have any clue about there being different 'types' of fibre connection. If I go onto BT's site now, they are only apparently offering FTTC. It's only when pushing further do you come up against the fact that actually it's different here, so you need to go about it a different way.
Sorry, but it's all being handled very badly. As I said, this is not directed at PN, they are at the mercy of OR, but they could make more information available to help clarify the situation. However, they don't officially offer FTTP so I can accept why they haven't so far. I would like to see them make FTTP a standard offering with FVA if required etc, but that's a different topic.
Anyway, I am of course delighted that the fibre is finally at the house and just need the internal fibre, ONT etc. Can't wait.
01-09-2015 12:25 PM
01-09-2015 4:05 PM
03-09-2015 12:10 PM
Thanks.
03-09-2015 12:40 PM
03-09-2015 1:15 PM
Current line speed:
0.5 Mb
03-09-2015 1:25 PM
Are you ok to check your speeds for me in 20 minutes?
Matty
03-09-2015 1:26 PM
