Alternative FTTC-compliant routers
- Full Fibre
- Alternative FTTC-compliant routers
13-04-2011 1:51 PM
Thanks...
Re: Alternative FTTC-compliant routers
13-04-2011 2:34 PM
There seem to be a good many to chose from depending on your price point.... eg. Linksys/Cisco E3000 at £100.
13-04-2011 3:44 PM
Any recommendations? I am looking for simultaneous dual-band, gigabit ethernet ports, reliable, good wireless performance... let's assume cost not an issue for now...!
13-04-2011 4:04 PM
13-04-2011 4:22 PM
13-04-2011 4:31 PM
Quote this country uses ppoa, not ppoe
It's not a geographical thing as some people believe, it depends on the exchange equipment. Some exchanges will even support ppoe on ADSL1
I'll keep watching this thread with interest.
13-04-2011 5:12 PM
Quote from: artificer this country uses ppoa, not ppoe, so why would the latter be of any use with fibre?
My understanding of this is that PPPoE, ie. PPPoEthernet is needed to send the login details across to the modem which then dials out with them.
So this is used anytime the router initiating the connection doesn't have a modem internally, I use this both at home and work, where a Sonicwall firewall with no internal modem causes, in my case a Draytek modem to connect to ADSL.
So PPPoA or PPPoATM is the think used by the modem itself when it wants to authenticate with the ISPs RAS or equiv servers.
So where FTTC is using a standalone modem, my understanding is that PPPoE will be needed by the Router to pass the login details to the modem. The modem can then use PPPoA if it requires, but as the router isn't connected directly to the line.
I agree with what Adam said, and believe it's not geographic, and indeed I use both PPPoE and PPPoA in various ADSL scenarios.
14-04-2011 1:03 PM
its great but it costs around £120
16-04-2011 2:00 PM
If others are interested I will post my experiences once it's in & running.
17-04-2011 12:17 PM
17-04-2011 12:43 PM
17-04-2011 1:03 PM
17-04-2011 1:17 PM
Red BT Infinity socket looks very much like an RJ45 i.e Ethernet - so would probably connect to the VDSL "modem" supplied as part of the FTTC install.
18-04-2011 2:44 PM
I'd err on the side of caution there as these are locked to BT by default (i.e it won't let you use it with any other ISP) There are ways around this but it can be a hassle from what I've come to understand.
Quote The latest BT homehub
I think a support library article with a list of FTTC friendly routers could be a good call....
30-06-2011 12:12 PM
So if looking for a new Router be sure that the PPPoE implementaion supports CHAP authentication - be interested to hear any suggestions for the best option which supports:
* Wireless G/N with a decent radio (2.4GHz-only would be fine)
* Detachable / upgradeable / extendable MIMO antennas (need to site the router 2m away from the antennas) - this rules out current Linksys and Netgear models
* (Ideally) 4 x Gigabit LAN ports
* Good Firewall / IPSec VPN passthrough.
May wait a bit until IPv6 support becomes mainstream and buy then, but if there's a reasonably priced interim which works (eg TP-Link TL-WR1043ND??) I'd be tempted...
Suggestions welcome
Brgds
Phil
- Full Fibre
