80 20 trialists - please read this
- Full Fibre
- 80 20 trialists - please read this
25-05-2012 3:49 PM
We'd appreciate it if you could take a couple of minutes to fill in this to give us feedback of the 80/20 trial and your experience of it:
http://www.zoomerang.com/Survey/WEB22FTH92AFJS
It'll only take a few minutes and the feedback will be invaluable to us when we come to design new products and choose the hardware to go with them.
FYI some of you may also receive an email regarding this but that doesn't mean we're asking you to fill it out more than once.
Thanks for the time, co-operation and feedback some of you have put into this.
Re: 80 20 trialists - please read this
25-05-2012 4:30 PM
Done.
Thanks for giving me the opportunity to take part in the trial.
James
25-05-2012 4:41 PM
25-05-2012 4:55 PM
25-05-2012 5:11 PM
25-05-2012 5:54 PM
25-05-2012 7:26 PM
or whats it going to cost to keep it ?
25-05-2012 8:13 PM
25-05-2012 8:32 PM
25-05-2012 9:28 PM
Katie
25-05-2012 10:42 PM
I also wouldn't pay extra. That is because although I can get the connection to run at close to top speeds, my router/wireless can't deliver much more than 40/10 to where I can use it i.e. 80/20 is more than I can actually benefit from. I suspect this will be true for many others in practice. But I think you'll need an 80/20 product as otherwise you'll look noncompetitive against BT et al.
I also get internet slowdowns, almost freezes, on 80/20 that I never had on 40/2. This too could be a router issue.
My ideal product would be 40/10 with an 80GB/month usage allowance, at the same price as the current 40/2 and 40GB/month. Then I could bin the Extra and buy Pro instead!
Many thanks for allowing me onto the trial.
25-05-2012 10:45 PM
25-05-2012 11:57 PM
I stated I would be happy to pay an extra £5 per month seeing as I get 76meg.
I can fully understand it not being viable for many people especially if you are only getting a few meg more than the 40/2 service.
26-05-2012 8:07 AM
Latency and uploads are more important to me so the 40/10 will suffice. That being said, I think the allowance is a bit too low as I'm constantly policing it at the moment.
26-05-2012 9:01 AM
Got a great speed directly connected to Cable Modem - 71/19 - But once router(s) were installed and wireless added (I have no option but to use wireless)
I am only getting round about 25/14 - and yes upload speed does seem excessive when compared to download speed.
- Full Fibre
