80/20 trial --- is 1.3mbps upload normal?
- Full Fibre
- 80/20 trial --- is 1.3mbps upload normal?
23-04-2012 11:20 AM
As a Fibre Pro user of about a year, last week I signed up to the 80/20 trial. Using the speedtest.net test, my download rate has increased from 34mpbs to 68mpbs, but my upload rate has only increased from 1.2mbps to 1.3mpbs.
I was expecting over 10mpbs upload speed: is such a small upload speed increase normal?
I'm using a Cisco Linksys E3200 router.
edit - correct typo in subject
Message 1 of 3
(1,419 Views)
2 REPLIES 2
Re: 80/20 trial --- is 1.3mbps uplaod normal?
23-04-2012 11:50 AM
I would say that is not normal, try as many different speed test sites as you can as I have found some seriously under-report the upload speed, although in my case speedtest.net generally reports between 11 and 15Mbps up.
Message 2 of 3
(330 Views)
Re: 80/20 trial --- is 1.3mbps upload normal?
24-04-2012 10:56 PM
I only get 1.6mb up at the moment - due to a completely ferked profile....
BT report it as 37/20 yet I'm getting consistently a 37/1.6 - and previously had a stable 73/16 minimum...
The Openreach Cabinet tool reports I'm on a 40/2 profile though
Completely screwed up.
Message 3 of 3
(330 Views)
- Full Fibre
