80/20 FTTC Trial Closed
- Full Fibre
- 80/20 FTTC Trial Closed
Re: 80/20 FTTC Trial Open
21-02-2012 9:46 PM
Quote from: dave The 20Mbps HTTP rate limit on Value Fibre and Extra Fibre is going to be removed soon (hopefully before the end of the week, it'll be going through our change control process tomorrow) for all fibre customers whether they are on Value Fibre, Extra Fibre, 40Mbps or 80Mbps.
Is very good to see. I'm not sure the limit has much impact on anyone's browsing.
However, after reading the latest Ofcom "broadband speeds" report, I wondered how things would appear once PN got a big enough set of fibre testers so they would appear as a separate provider. It wouldn't have looked impressive against Infinity and Virgin.
In that report, the "actual" speeds for all variants of "super-fast" compare very favourably against the headline speeds - and miles better than ADSL2+. It would be a marketing blunder for the numbers in such a report to be artificially hobbled.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
21-02-2012 10:02 PM
As part of setting this up, do you get better speed predictions from BT than we do? The standard checker we can get is capped at 40/10.
21-02-2012 10:17 PM
Quote from: andun84 My order should complete within 1 working day ...
Just got my confirmation email
21-02-2012 10:17 PM
Plusnet Technology
21-02-2012 10:41 PM
Quote from: dave There's no special usage allowance on the trial so you'd have 40GB on Value Fibre or 120GB on Extra Fibre.
During the trial you are free to move between Extra Fibre and Value Fibre as you wish, this won't affect the 80/20 trial. At the end of the trial there is no obligation to keep 80/20, you can switch back to what you have now and continue paying the same amount you do now.
the problem is that i'm not on either of those i was on the fttc trial and so on orig product with pro addon
which i'm fine with EXCEPT it has a 20gb limit which i keep almost going over
i think if i change to one of those FTTC products i'll end up paying more won't i?
i cannot afford to pay more...
any thoughts? anyone?
21-02-2012 10:50 PM
21-02-2012 10:59 PM
Plusnet Technology
21-02-2012 11:10 PM
Quote from: dave ... estimates varied from mid 50s to mid 60Mbps on most ...
For a while the BT ADSL checker gave me estimates of 60.5 down and 20 up (before reverting to 40 down and 10 up), my original fibre estimate was something like 30 down and 6.5 up but I got the full 40 down even on the old 8c profile, it'll be interesting to compare the new estimate with what is achieved (hopefully it'll be as accurate as before though I'd be surprised if I get 80 down).
21-02-2012 11:48 PM
22-02-2012 12:06 AM
Quote from: mikeyriot As some other posters have noted, before I commit to a package change (in my case extra to fibre value/extra) will I be able to revert to my original package (that being extra) as well as keeping the 10 up if I join this trial?
I know exactly what you mean dude. I have just switched from my old legacy pack to go to PlusNet Value Fiber just to get on this trial. The things I do for raw speed lol. I just hope this doesn't bite me in the bum? So heres hoping now.
22-02-2012 1:00 AM
@dave
Thanks for the very rapid progress. I am now synced at 64,525 / 20,000 🙂
Downstream looks to be working well. For some reason the upstream is being capped at 10Mbps as evidenced by real world speeds and the fact that the BT speedtester is reporting my upload IP profile as 10Mbps. I will keep an eye on it and see if it changes.
James
22-02-2012 7:31 AM
Really happy with the results!
Paul
22-02-2012 7:42 AM
22-02-2012 8:19 AM
This was using a wired connection, best I ever got on the original product was
and that was via wifi.
I've never seen 40Mbps before so I'm assuming the order has completed. I also believe I am somewhere between 750-800M from the exchange so I'm not expecting anything like top speeds but the BT checker briefly showed 16Mbps up when it showed > 40/10 figures and when the FTTC was installed the engineer showed me on his magic kit the line would support more than 10 if BT supported it.
Assuming there is a new training period I'm hoping this might improve otherwise any cost for 80/20 will not be worth it.
22-02-2012 8:44 AM
Not a bad start
I'm around 300m from the cabinet, all underground but there's a clear line of BT manholes from one just in front of my house all the way to the cabinet (measured by pacing the route), that's not to say there isn't a bit more wire length, especially with the link between the old cab and the FTTC cab (around 25m apart).
Resync took place shortly after midnight, TBB monitor shows it nicely:
