500mbps connection 1-90mbps speed consistently
Fixes: 236
Re: 500mbps connection 1-90mbps speed consistently
If you run task manager, performance tab and look at the network graph, what does that report?  It show show utilisation and connection speed.
The fact that you get 500mbps over ethernet proves that there is no issue with the FTTP service here, but rather a local / environmental challenge with WiFi.  The usual WiFi inspection with inSSIDer and ensuring that the chosen channel is not congested seems like an appropraite approach.
bobpullen
Fixes: 327
Click the network/Wi-Fi icon in the task bar, go to the properties for your active Wi-Fi connection and scroll right down to the bottom of the resulting window. What Wi-Fi radio is the laptop connecting to and what is the PHY rate?
Fixes: 236
@bobpullen
I will add this to the boiler-plate response we developed... just need another roundtuit.
