36Mb/s FTTP upload speed
briank
Re: 36Mb/s FTTP upload speed
What is the process to submit a request to get this issue investigated?
The old method of raising a ticket appears to be defunct.
I can't find any kind of chat assistant.
The only information I can find suggests "troubleshoot by text". (Text HELP to 07800008121).
That sounds like a longwinded and expensive method (my ASDA Mobile PAYG charges 10p/text).
Fixes: 531
@briank because you are still on an FTTP trial provision , the normal fault procedures won't work very well. You need to wait for one of the PN help team to pick up this thread. They will understand about the FTTP trial. If noone picks this up today, then I'll try escalating it to get some traction.
MatthewWheeler
Fixes: 503
Sorry to hear this @briank
I've placed an order to change this which will complete tomorrow.
As others have advised it may be worth checking your upgrade offers here as there'll be better deals than what you're currently on.
If you do this let us know as due to you being on the trial we'll need to do some bodging
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Fixes: 531
@MatthewWheeler  thanks for picking this up. So was it somehow provisioned on 40/2 ?
RobPN
Fixes: 13
@briank
Sorry, but yep, 10p per text seems expensive, IMO just as Vonage VoIP is at £10.25 per month!
briank
Problem now sorted.
Speed check indicates 36->37Mb/s download, 10Mb/s upload.
Thanks for all the help.
