1MB Upload speed
superflyin1
1MB Upload speed
I have 1MB upload speed. Is that normal? Download speed download  is 20MB.
5 REPLIES 5
corringham
Seasoned Champion
Fixes: 23
Re: 1MB Upload speed
Do you have an ADSL or an FTTC line? 20Mb down and 1Mb up is good for ADSL. Although FTTC is faster than ADSL, it degrades with distance more than ADSL does, so if you are a some distance from the cabinet your speed may be all the line can reach.
You can check what the predicted speed is for your line by checking http://www.dslchecker.bt.com/
MatthewWheeler
Fixes: 503
Thanks for your post @superflyin1
It looks like when activated your fibre service we put you on the wrong product on our suppliers systems which limits your upload to around 2Mbps.
I've placed the order to correct this for you which will complete tomorrow and should give you faster upload speeds.
Let us know how you get on
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
superflyin1
Hi
 DOWNLOAD 30.87Mbps
 UPLOAD 2.07 Mbps
Mads
Fixes: 79
Hey there @superflyin1,
Thanks for getting back to us.
I'm sorry you are still not receiving the upload speeds & I apologise for the frustration caused. On testing the service today it appears the line is banded, as such I have sent a request for this to be reset - it can take up to 72 working hours.
Thanks.
superflyin1
Thanks for the help. Upload speed has been fixed now.
