signed up but
signed up but
Hi I just signed up to plusnet 2meg premier. I should be migrated over in a few days but I dont know what I need to login. Do I just use my user name and password I used when I first signed up to connect and do I have to put different settings in my router or anythin. Sorry im just a newbie
signed up but
You should get an e-mail with your connection settings b4 migration is complete. They are different to your normal user/pass
signed up but
ok thanks no7. Cool
signed up but
It will be something like njc27@plusdls.net and your login password.
signed up but
Surely you mean plusdsl.net? Wink
signed up but
ok thanks all I was just flickin through Connection settings and also saw
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
Optional tertiary DNS server 212.159.6.9
Will I add these to my router when I switch over as well
LiamM
signed up but
If you have ever manually changed the settings, then you will need to do so. But if your router is set to automatically retrieve the settings from the ISP (most likely), then you'll not need to manually set these.
signed up but
ok thanks martinfamily so all I need is user name and password then. Sounds easy enough lookin forward to speakin more when I get migrated Cool
signed up but
I did say "it will be something like" Cheesy but thanks for spotting the typo Cool
